Help to improve FPGA DMA on cRIO-9068 and ni-9201
I am  trying to add 2 NI9201 module to my cRIO-9068 (FPGA code was previously build by another person) and i need to run the acquisition as fast as possible. I am new to work with FPGA so not sure what is the best way to approach the programming.
I have tried to different way but they both return me different result. I am tying to measure a pulse of 80 us and i know the module can read each channel at 2us, since i use 3 channel on each of the 3 ni-9201. I think i should be fine if i take 100 sample to cover the whole pulse?
When reading the data on the host i see the pulse on one channel and only get peak on the other channel of the same module.
Any advice will be welcome.
Using Labview 2015.
(2,366 Views)
Accepted by topic author Frankr21
I should have tried the example VI of the NI 9201, it has fixed all my issue.
I was just to lazy to modify the RT code, but it will be better i guess.
 Much cleaner anyway
(2,344 Views)
