NI 4145 Multi-channel DC Power supply program
Hi guys,
I want my NI 4145 to output 4 channels DC current, each channel current can be changed. When I program for it, I see some problems. I think in my application, what I need is sequence current. If I configure it to be sequence mode, then it tells me if you have multi-channels in one session, then I need to switch to single point mode. Then I tried single point mode, when I run it, the system says 'niDCPower Initiate VI 'run.PNGhas error that this session is already running.
So I don't know how to deal with it.
Anyone has ideas?
I also attached my VI.
(2,481 Views)
Accepted by topic author zyb1003
Hi Guys, I think I just solved the problem!
I removed that VI from while loop to outside in front of the loop and it works! I think that VI is only able to run once in one session, the while loop just keep running configure mode
(2,472 Views)
