Searching for a overview of ini file settings
Am looking for a list of all ini file parameter settings for my executable. For example, to set the window size
(2,395 Views)
There are some special ini keys you can add, but I don't think there is one for window size, especially since you can set that in the VI properties or programmatically.
Here is an article highlighting some of the ini keys you might use. The first table is for LabVIEW (effecting your development experience) and the second is for an executable that you create with LabVIEW.
All the LabVIEW ini Treasures You Were Looking For
(2,388 Views)
Do you have another link to your list of ini keys? I cannot access the one you posted.
(2,315 Views)
