Help with Acquiring a Continuous Waveform from Siglent sds 1074 cfl
I am new to LabView, I have been searching allover to find any information on acquiring  a continuous waveform from Siglent SDS1074 in to LabView.
After so much struggle I was able to have LabView Identify the scope via Visa using SCPI command (*IDN?).
My goal was to acquire a continuous waveform from the scope using the attached VI Bock Diagram image.  The SCPI command, according to the SDS1000 Programming Guide provided from the vendor, is “C1: WF?”.
Running the attached VI shows a flat line with no errors.  When I randomly stop and start the program I seem to get the square wave from the scope, but it goes away in few seconds!
Please help, if anyone is familiar with VISA coding!
Thanks in advance!Visa_Block_Diagram
Message 1 of 8
(4,751 Views)
Why are you reducing the waveform to a single point? Please provide the contents of the string you get back.
Message 2 of 8
(4,746 Views)
Sorry about my ignorance, but how do get contents of the string?
Message 3 of 8
(4,735 Views)
Create an indicator.
Do you do any basic debug at all before writing some code? A first step would be to test the commands in MAX.
Message 4 of 8
(4,725 Views)
No decoding at all!  I am getting my bits and pices of info from youtube!
Actually you asked the question I was pondering about.  To get somekind of reading from my VISA Read (read buffer) to see if I am getting something out of it!  Identifying the scope works acording this block diagramIdentify BlockDiagram.PNG
What kind of indicator do you suggest?
Message 5 of 8
(4,722 Views)
You've got exactly one choice for an indicator. It's exactly the same type you used for the idn query.
Message 6 of 8
(4,711 Views)
Cool i will try and reply with my result.
Thanks for the response!
Message 7 of 8
(4,704 Views)
In MAX, VISA Test Panel, on the Input/Output option, Write gives no error; however, Read and Query give the below error:
"VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed." (*IDN?\n)
Sometime it shows the identification and sometimes it gives the above error!
Message 8 of 8
(4,694 Views)
