Issue with How Do I Run an Executable in the Background ?
I am trying to run a LabVIEw executable in the background, but none of the methods described in the discussion forum and on ni.com seems to be working. I am using LV 2011 on a Win 7 64-bit machine in case this matters.
I tried the method described in "How Do I Run an Executable in the Background as a Start-Up Application?" (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KrbSAE&l=en-US but I still see a fragment of a window at the bottom near the start-button (Exhibit 1). Exhibit 2 shows that it only consists of the title bar. (I have customized the window appearance as described, and added the two items
HideRootWindow=True
UseTaskBar=FALSE
to the *.ini file.)
I also tried disabling all the other items in the Customize Window Appearance menu with the same result.
Then I tried the method described in "Running a LabVIEW Executable as a Background Process" (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIIzCAO&l=en-US) adding the FP.Open method to the VI and setting the state to hidden. I got the same result (Exhibit 1).
Is there anything I need to do in addition or different for my windows version? I appreciate your help. Thank you.
(5,100 Views)
HideRootWindow=True
UseTaskBar=FALSE
to the *.ini file.)
No you did not
They need to go in the exe's ini so the exe sees themSmiley Wink
(5,087 Views)
Actually I did when I tried out the first method. Then for the second method I tried both with and without these two items in the ini file with the same result( Exhibit 1)
(5,076 Views)
Accepted by topic author pbuerki
I found the issue. It was an incorrect directory name for the build. I kept running an older version of the executable with the default window settings. The method described in How Do I Run an Executable in the Background as a Start-Up Application?" (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KrbSAE&l=en-US works.
Sorry, all for wasting your time. Mea culpa.
Peter
(5,066 Views)
That is great!
First- I'm happy you found the trouble
Second- more details for the next guy?
Kudos!
(5,050 Views)
