Help with HP counter vi !!
I'm having trouble getting the counter to track a Rhode & Swchartz Sig Gen.
The counter will initialize, be put in remote, but just hangs once the sig
gen starts to increase frequencies from 100Mhz to 2Ghz. I'm using the agilent
instrument vi(read a measurement.vi) off their web site. Does anyone have
any other ideas or solution
about a possible fix.
Thanks. Jeff
(2,574 Views)
I have modified the VI hp5313xa available on vi.com, including close.vi, VISA interface, precision of 0.01 Hz for frequency measurement and it works now.
One of the problem in the original driver was result a conversion problem (use of decimal point in the data returned by the instrument)
In attachement is given the modified instrument driver
for the HP53132A"
(2,574 Views)
