Help with Help
How do I remove the Search menu item from the Help Menu ?
See jpeg
(3,669 Views)
I don't see that on my Windows PC, and it looks like you are running on a Mac.  It seems to be something caused by your operating system and not LabVIEW.
You may want to research your question on some Mac forums.
(3,666 Views)
I thought this was a Labview Forum, not a Windows forum.
I thought Labview was cross platform.
(3,664 Views)
Yes.  It is a LabVIEW forum.  But it appears you have a Mac problem, not a LabVIEW problem.
(3,660 Views)
Where is the Macintosh Forum?   I've made several passes thru
the forum list and can't locate one.
(3,656 Views)
Almost every Mac program has the Help menu item with the search capability.  ( I have one old game which does not).  It may be something which Apple requires or encourages programmers to put into their Mac programs.
Yes, this is a LabVIEW Forum and LV is a cross platform application.  All cross platform applications must adapt to the platform so LV, Adobe Reader, or Filemaker databases will all look and behave slightly differently on each platform.
Check with Apple's Developer support to see if there is a way to suppress that.
Lynn
Using LV on the Mac since version 1.2
(3,654 Views)
There is no Macintosh-specific LabVIEW forum or Windows-specific LabVIEW forum on NI.com.
I'm talking about a Mac forum somewhere else on the internet.
(3,651 Views)
