How to execute Show Desktop.scf in Labview?
Dear all,,
 Can anyone tell me how to excute Show Desktop.scf in labview?
Santhosh
Message 1 of 9
(4,909 Views)
Hi Santosh,
you could use SystemExec to call any external application from LabVIEW...
Message 2 of 9
(4,904 Views)
I have allready tried this pallet...Its not  working...
Santhosh
Message 3 of 9
(4,902 Views)
Accepted by topic author Naveen Santhosh
Dear GerdW
Finally I did this VI with some method..Let me know if anyother better way is there...I m attaching VI..Look at it...
Santhosh
Message 4 of 9
(4,894 Views)
Hi Santosh,
so you finally took my advice on using SystemExec to call an external application? Smiley Wink
Message 5 of 9
(4,891 Views)
Hi Naveen,
I was trying to find right command for this.
CMD /C "C:\Documents and Settings\Username\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf"
This is string generated and given to command line input. (In your code)
I did not write "/c"..I was trying with following string. Smiley Sad
CMD  "C:\Documents and Settings\Username\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf"
So close..this was something I enjoy..Try to do something new. Thanks for the solution. Smiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 6 of 9
(4,886 Views)
Actually before posting this i have tried with the same pallet..It doesnt work as it will work for other Executables...So i called it from Command line..
Santhosh
Message 7 of 9
(4,885 Views)
Santhosh
You could also have used the Windows function "ShellExecute". You wont see a console window with this.
Then again... you could run the system exec vi minimized.
Message 8 of 9
(4,870 Views)
Santhosh,
The nudge/wink from Gerd was that he was the one who gave you the answer to your question about using SysExec to execute the command.  So the right thing to do would be to mark his post as the solution to your problem and not your own post.  You can unmark your post as the solution by going to the options menu to the upper right of your message.
Message 9 of 9
(4,867 Views)
