Help with Relay Loop
That makes sense. You can continue to use this type of structure to do what you want, where "All Fans ON" sets the Next Count to 1, and "All Fans OFF sets the Next Count to 0. Alternatively, you can look into using the Event Structure to precisely control when something happens, including timing of your program. Event structures are extremely useful, but also slightly more complicated.
Robot wink
Message 11 of 16
(1,858 Views)
hello Sir,
 i wanted to know how did u finally control the fan on off sequentially. actually i have to control the lamp load with this logic
plz do reply
thanks
Message 12 of 16
(1,704 Views)
Hey p^2!
This forum post is pretty old if you check the time stamp, and I'm not sure we will be able to get much out of those who worked on this before.
If you have a specific question that we could answer it would be better to create a new thread. That way we can pool the resources found on the
forum to help solve your problem.
Rob S
Message 13 of 16
(1,669 Views)
i want to make light on and off sequentially not make it on and off at one time. i tried to make it on but for making off itz not working properly. itz giving two lights off at one time. how do i coorect it to make it off sequentiallly?
Message 14 of 16
(1,652 Views)
thank you Sir to reply me and for giving your time frm your busy schdule!!!
Message 15 of 16
(1,651 Views)
p^2,
If you create a new thread with your blinking light question you can recieve more help from others who will review the post.
Rob S
Message 16 of 16
(1,631 Views)
