Help with School Labview Assignment
Hello!
I have a school assignment that has to be done by tonight. I have figured out how to do the basic program and it works. The things I am struggling with is how to make the radio buttons (subtask 1) work with the code and the three diffirent states. Im wondering how i should do to integrate the radio buttons with the code. I would also appreciate some help with subtask 2.
Thanks in advance!
Message 1 of 10
(4,717 Views)
Accepted by Westen
Hi Westen,
connect the RadioButton to the selector of a case structure. Then create a case for each item of the RadioButton: that's a right-click menu item.
Now there are 3 cases, one for each payment option…
On task 2:
All you need is an array of 4 LEDs. Initialize with 2 LED on (TRUE) and 2 LED/elements off (FALSE). Then rotate the array by 1 element with each iteration…
Message 2 of 10
(4,685 Views)
Thanks for the good answer!
But why does this happen when i make a case for each radio button?
Message 3 of 10
(4,644 Views)
You are duplicating the cases, including the controls and indicators inside of the cases.  It seems to me (I have not looked at your code, only the last image you posted) that you should not have your controls or indicators inside of the case structure.  Instead, pass the values into the case structure and you then just use the values you care about: similar for the indicators.
Message 4 of 10
(4,625 Views)
Okay, but everything should be in a while loop right?
Message 5 of 10
(4,616 Views)
Okay, so I solved the case problem. Now I am wondering how I can change the string indicator to a sentence, so it says "The total price is [price] SEK"
Message 6 of 10
(4,609 Views)
Format Into String
Message 7 of 10
(4,603 Views)
I do not really understand, i can build a array and wire it to a 1D rotate. What functions should i use?
Message 8 of 10
(4,587 Views)
What does this mean?  What are you trying to do?  You really should attach your actual VI (so we can really examine it with LabVIEW, edit it, execute it, etc.) -- sometimes a VI is worth a thousand screen shots of Error Messages, pieces of Block Diagrams, etc.
Message 9 of 10
(4,563 Views)
Okay, I will have that in mind for the future topics. Thanks for the input.
Message 10 of 10
(4,545 Views)
