Help with TCP/IP memory leak
There is a memory leak in the attached vi that I am unable to find. The purpose of this VI is to read incoming strings from a custom instrument via TCP/IP port 23 (telnet).
The main VI that runs in the attached folder is "CI Instrument Communications.vi". The vi will leak approximatley 2GB of memory over an 8 hour period. Please let me know what you guys can find.
(3,437 Views)
Why do you keep opening and closing your ethernet port?  You only need to open it up once.  You are just adding a bunch of overhead to the TCP layer.
Also the constant building of the string could lead to issues.  I don't think that is your issue, but it is something to look into.
(3,381 Views)
Thanks for the reply. I originally wasn't closing the connection after each call, but I decided to try it to see if not closing it was the cause of the leak. In an example I found the connection was being closed and re-opened each loop iteration. This didnt fix the issue, so i'm still searching.
I'll look into the string.
(3,372 Views)
