Help with architecture used in core 3
I would like to use the architecture from the LabVIEW core 3 module for a project. I made some modifications to it and I'm unable to get it to stop when I pull down "File" in the upper left hand corner and click on "Exit". I've tried setting up probes and walking through the code but I still can't see the issue.
In the lower loop there is a case called "Select 1". If I get rid of the code in that loop the application stops as expected.
Any help is appreciated. To run just unzip, open the project and run "Main_1.0.
Thank you,
Chuck M.
(2,790 Views)
In your Display Module.vi, you are not sending the Shutdown command.  Therefore, your display loop will not get the command and never stop.
EDIT:  Nevermind, you are.  There are just so many enums with common names running around, I got lost.
If the Select 1 case is causing issues, I'm guessing it is throwing an error in the variant conversion.  Make sure you are passing the proper data and converting it properly.
(2,783 Views)
I'm not sure what you mean. Do I have to modify "Display Module.vi" to correct the issue?
(2,779 Views)
Accepted by topic author chuck72352
Found it.  Look in your Initialize.vi.  You will find a Display Module sending the Select1 command.  But the data is a variant.  A raw variant.  This cannot be converted into a numeric.  Therefore, an error is being thrown, the queue will never be read again, and you will have an infinate loop.
You just need to wire in a value converted to a variant into the data here.
(2,776 Views)
I see now.
Thank you.
(2,773 Views)
