Help with binary file to spreadsheet conversion!
Hallo all,
I got a binary file containing two-column data, one column lists the time, the other are measured data. I try to convert them into a spreadsheet for further processing in Excel using the attached file. However the string to 2D conversion error pops up.
Any advice is welcome.
win2
(3,008 Views)
You need to wire a 1D array to the Type Cast function and then use a Decimate Array to get a 2D array. See pic below:
Message Edited by smercurio_fc on 05-02-2007 01:15 PM
(3,004 Views)
