How many data points can there be in a waveform graph
I have 35 lines of the data  that I want to show in one waveform graph. Is there a limit on how many data points per each line?
Thanks.
(3,009 Views)
I doubt that you will run into this issue, most likely the (virtual) memory of your computer will limit you. Notice that the general width of a graph (approx. 1000 pixels) will limit you earlier.
Ton
My LabVIEW Ideas
(2,991 Views)
J3000:
Have you tried plotting those values? Post again if you are running into any snags.
Rudi N.
(2,970 Views)
