Help with combination of Ring,Control and String Indicator
I have a simple task to perform, but I do not know if it is possible or not. I have the list of names in a ring, and I have a digital control that I want to change for each person. The names and person must be displayed on a string. I have attached a picture jof what I want .
Also, whenever the user changes the value of the ring, the digital control must correspond to the value of the name or defualt of zero.
(2,467 Views)
I'm not quite sure what you want to do.  It should be a matter of using the ring Properties to get the name.  Sample code (LabVIEW 8.5.1) attached that should help you on your way.
(2,457 Views)
