Help with editing a 3D Mesh Object
I am attempting to edit a 3D mesh object continuously but I am having some trouble with referencing the created mesh. I have attached screenshots of the .vi for reference.
On first call of the VI, it creates all the 3d objects and displays as expected. But on subsequent calls, the mesh object that I am trying to reference and edit the properties of does not appear to be referenced correctly. I am specifically talking about the object I have named "Cables". When I try to reference the mesh object by using the "To more specific class" function, it throws the following error. I am at a loss for how to properly reference the mesh and edit the parameters of it. Do I simply need to just delete the object and create a new one every time?
Error 1057 occurred at To More Specific Class in Create Motion Path 3.vi->Host-Main.vi
Possible reason(s):
LabVIEW: (Hex 0x421) Type mismatch: Object cannot be cast to the specified type.
(939 Views)
We cannot run or debug pictures. Create a simplified VI with all controls having typical defaults and attach it here.
(Use "save for previous, 2020 or below if you use a recent LabVIEW version)
(863 Views)
Here is the VI saved as 2020 version. I have saved with some default values. The only value that you should need to alter for debugging is the "Current XYZ" control. If you can imagine that there is a payload hanging from 4 cables and when you change the current XYZ, the point should change and the cables will move with it. The first loops iteration works and displays as expected, but on subsequent iterations the reference to the "Cables" mesh throws an error.
(816 Views)
Accepted by Zuol
Use a property node to get the Drawable reference. You can typecast that.
(805 Views)
Ahh Perfect! Thank you that was exactly what I was missing. I appreciate the help!
(800 Views)
