Help with error 1802
I am bringing in a 60Hz 5v p-p sine wave in from a parent VI.  I am using the limit tester to make sure the signal is there (testing for greater than +-1v).  I keep getting error 1802. It says I have different dt values for the waveforms.
I have looked on the boards and don't see a solution that applies to this problem.  The VI is attached.  Any help would be appreciated.
(4,759 Views)
Did you look at this article?  http://digital.ni.com/public.nsf/allkb/C41966093C3D030F86256FF8007F8BF5
The dt of your waveform should match the dx of the upper/lower limits.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(4,752 Views)
Yes I did, but those solutions deal with two signals that need to be synced together.  My problem is that I have one signal coming from a source through a limit tester.  I'm not quite sure what I need to sync the limit tester to.
(4,750 Views)
Here's the VI so far.
vi
(4,739 Views)
Did you make sure that the dt of your waveform matches the dx of the upper/lower limits?  Please post your VI
(4,736 Views)
It doesn't look like you have the upper and lower limits wired.
(4,732 Views)
