Help with jagged png images
I have a picture control that I am wiring a png pixmap to and keep getting a jagged image. If I open the image in any number of viewers it looks fine, but when I look at it in labview with the picture control it looks jagged. Example is attached look at the green valve, the edges are all wavy. Thanks.
(3,392 Views)
Hi Icemaker,
a PNG with "wavy" edges in a JPG compressed picture isn't very helpful...
Is there any alpha channel in the PNG? Is it in 8bit or 24bit color resolution?
(3,378 Views)
Sorry about that. Attached is one of the valves. It is transparent PNG 24bit.
(3,374 Views)
Accepted by icemaker
Hi Icemaker,
have you tried to use 8bit PNGs instead?
(3,364 Views)
Gerd,
I recreated at 8-bit they are much clearer. Thanks!
(3,315 Views)
