Help with my while loop
The loop doesn't seem to be working for me. I have ran it a couple times but can't seem to find the problem. The output value is also not the same. It also does not run continuously, for me. I even went through the block diagram and it looks like it should work, but I can't seem to see why it doesn't.
I also attached the pump_repeat file you sent me. I may have misdownloaded it. So I want to see if you can open it on yours and see if it has the same issue. What I did when you sent me the file was: I downloaded the statemachine.ctl from you and saved it. Then I opened the vi with a reference to the statemachine.ctl. See if you have the same issue.
If anyone can offer some insight that would be great!
Thank You
Message 11 of 14
(1,306 Views)
Thank You
Weird. I didn't have any problem opening the VI and the .CTL. I made a small change to the shutdown condition in the new VI I am attaching with this post. In your pump data picture, when you say your VI, you are referring to your VI from your original post?
Message 12 of 14
(1,294 Views)
Yes that is correct.
Also, when I change the frequency, it's supposed to revert back when I stop and then start the vi again, right? But if I change it while the vi is running, nothing happens to the output...
Sorry for all the trouble.
Thank you so much for all your help.
Message 13 of 14
(1,284 Views)
Ok, I made a small mistake on the code. That's what happens when I write code in a hurry 🙂
Go ahead and wire the frequency wire through the "running" case.
Message 14 of 14
(1,278 Views)
