Why do I receive Error -200077 Daqmx Read when scaling should be within range
I have an application using a NI-9215 and custom scales.  The task and scales are all setup programmatically.  I am receiving an error that the AI.Min value is out of range but when I check my scaling it seems like it should be fine.  I have attached an image with the error message and also the scaling that I am using (slope and offset) for each channel.  I have calculated the allowable min and max values for each of 3 channels based on the scaling and min/max range of the 9215 (+/-10V).  For all of the channels I am trying to set the AI.Min = 0 and AI.Max = 13 but I receive the error message even though these values are within the calculated ranges.  Is there something else I am missing?
Dan
(2,998 Views)
Accepted by topic author DBerry
Solved
(2,969 Views)
You should say how this was solved.  That way other people can learn from your experience.
(2,961 Views)
operator error - default scaling values being passed rather than expected values.
(2,959 Views)
