Why do I receive Error -200077 Daqmx Read when scaling should be within range
I have an application using a NI-9215 and custom scales.  The task and scales are all setup programmatically.  I am receiving an error that the AI.Min value is out of range but when I check my scaling it seems like it should be fine.  I have attached an image with the error message and also the scaling that I am using (slope and offset) for each channel.  I have calculated the allowable min and max values for each of 3 channels based on the scaling and min/max range of the 9215 (+/-10V).  For all of the channels I am trying to set the AI.Min = 0 and AI.Max = 13 but I receive the error message even though these values are within the calculated ranges.  Is there something else I am missing?
Dan
(2,995 Views)
Accepted by DBerry
Solved
(2,966 Views)
You should say how this was solved.  That way other people can learn from your experience.
(2,958 Views)
operator error - default scaling values being passed rather than expected values.
(2,956 Views)
