Help with resetting loop iterations back to 0
Hi Steve,
I'm sorry to say that placing a zero constant on the shift register did not work.  I was ready to bet you on this (but not cash or anything) lol, only because I had already tried that approach. When I did place a zero constant on shift register, every time I press start, iteration starts at 1.  What I did do by your earlier post is change the Set # of Cycles to an I32 data type and change the equal sign to a greater than/equal to.  This works as expected, if I start vi with iteration higher that set # of cycles, VI will run 1 cycle then stop.  This is acceptable.  I want to thank you for all your help and insight.  I knew I was close but phenomena happened when I tried to add "reset" logic.
Message 11 of 11
(627 Views)
