Help with scaling of chart
I have a problem manipulating the scale of the graph here.
in the VI that i attached, there's two chart. The one at the top is the problem that i am facing. I want to have a chart that has time on the x-scale in 24-hr format with increment of 1 hour. For the first chart to show every hourly value on the x-scale i have to stretch it too much and the incremental value becomes 30 minutes.
I intend to remain the size of the chart as the chart at the bottom.As you can see, the x-scale can not show every hourly value from 08:00 09:00 10:00 all the way to 20:00.
This should be what i want to get
08:00 09:00 11:00 12:00 13:00 14:00 ... 20:00 x-scale
and maintaining the size as of
i've tried changing property node values for interval, max, min to no avail.
Thanks for any help
Parker
(2,611 Views)
Hi Parker,
In your second graph you've got 8:00 - 12:00 - 20:00. What you need to do is replace the 12:00 by 9:00 (clic on 12:00) without adjusting any property.
The graph should then show the different times you want.
Hope this helps !
Julien
(2,611 Views)
wow that works like a charm
how did i not try that? thanks so much mate 😃
(2,611 Views)
