02-13-2006 05:06 PM
02-13-2006 10:25 PM
Your sub VI " draw stacked Graph.vi" is missing
02-14-2006 05:03 AM
I believe that you can only have horizontal bars when using an "XY Graph".
Check that you are using an "XY Graph" (not a "Waveform Graph" or "Waveform Chart").
The XY graph requires a different data type that includes both the X and Y coordinate values - I've attached an example based on the "Stacked Bar Graph" example.
Mark.
02-14-2006 05:13 AM
P.S. "Untitled 2" is the "top level VI" in the LLB file.
(50:50 chance of confusion there).
11-15-2006 09:26 PM - edited 11-15-2006 09:26 PM
Message Edited by tca-adam on 11-16-2006 01:27 PM
11-16-2006 07:49 PM
Have you see this>>
