Help with state machine and event structure
I have a state machine that is controlled by button presses.  A single button causes a state change, but the state to move to depends on which state you're currently in.  In other words, if I'm in state X, pressing button A will move to state Y.  If I'm in state Y, pressing the same button A will move to state Z.
What is the easiest way to do this? I tried using an event structure for this but haven't been able to get it working.
Thanks!
(3,574 Views)
Using a state machine with an event structure is often a nice way to go !
If the next case depends on a combination of the previous and another event you can keep track of the previous case using a "dropped down shift register" see pics below 😉
Hope this helps
Message Edité par TiTou le 07-10-2006 02:24 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,570 Views)
Could you elaborate anymore on how to set this up?  You can't have an event handler in each state of the state machine...
(3,567 Views)
of course... a bit of code is worth a long speech, so have a look at the example attached. I just started from NI template "Standard State Machine" and added a case called "user Interface" in which I wait for an event and then see what was the previous event to decide where I shall go next 😉
Epictetus
Antoine Chalons
(3,556 Views)
