open daq assistant from front panel
Is there anyway to open the daq assistant from the front panal at run time.  I know you can convert the DAQ assistant and then open front panel using the functions in the application control palet, but I would perfer not to do that.
BJP
(3,163 Views)
Hello BJP,
I am not entirely sure what you want to do.  When you have the DAQ Assistant on the block diagram of your VI, and you run that VI, you cannot open the DAQ Assistant while that VI is running.  You also cannot view the front panel of the DAQ Assistant while the VI is running.  If you want the front panel of a subVI to open while your VI is running, you can do that.  You can make your subVI perform the actions of the DAQ Assistant that you are interested in.  For example, if you are using the DAQ Assistant to do digital input, your subVI that opens up could perform that action.
Let us know if you have additional questions.
Laura
(3,144 Views)
Thank you, you answered my question even though you did not no what I wanted to do.
Brent
(3,134 Views)
