Help with timing controls
Also, thanks for everyones help! I would still be very stuck without all of your help.
Message 11 of 13
(608 Views)
@Adam_Keller wrote:
I got this working, but is there a way for the array to reiterate? I want this sequence (picture is attatched) to occur over and over until the process needs to stop. I may need to have to run this for hours.
Message 12 of 13
(591 Views)
make sure you initialize your digital lines array with the same amount of enabled bools for channel outputs, you will get a Daq error message....not match!
Message 13 of 13
(580 Views)
