Here as a query instrument data code, from here to appear "query interrupt", what is the problem?
(1,254 Views)
Hi peitao,
what about using AutoCleanup before posting images of your code?
What about sending the request (the command with the "?" at the end) as the last command after setting all parameters?
(1,229 Views)
GerdW is right here.  A lot of instruments will give you this error if you send a command while it is processing a query.  When you send the query, you need to read the response before sending the next command.
(1,220 Views)
