LabVIEW FPGA VI compilation -timing errors
I have code in different Single cycled timed loops of 60 MHz, 40 MHz, 100 MHz with NI streaming code.
when I am trying to compile it for PXI-5840 using NI cloud compiler, it is giving timing errors.
Individual SCTLs loop are compiling fine.
When combining the both , I facing this issue.
In the timing violation window, it showing non-diagram component in Streaming code.
I am not sure where I have to optimize?
I tried reducing the clocks rate and checked. still issue remains.
By changing implementation strategy  xilinix options , Can I solve this?
thanks in advance.
(1,570 Views)
Can you confirm that you are recompiling for the VST (5840)?
Can you provide more details such as screenshots of the failures.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,552 Views)
