(Hex 0x465) Error code 9: VI version (24.0) is newer than labview version (21.0)
I have this error
I have redownloaded labview, the licenses are up to date, I have the latest version and everything was working until a VI appears to have been opened.  When I look up how to fix the problem, it just says this is a known bug with LabVIEW 2019.  Any help is greatly appreciated.  Thanks.
(1,696 Views)
Hi a,
  • The error message is about LabVIEW2021, your text mentions LV2019: how does it relate?
  • Why do you "redownload" LabVIEW?
  • Generic answer: you cannot open VIs from newer LabVIEW versions with an older LabVIEW version…
(1,691 Views)
You cannot open a VI that is saved in a newer version with an earlier version than that one.
try this to convert your VI to an earlier version "https://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion"
(1,676 Views)
Do you have multiple versions of LabVIEW installed? You may need to start LabVIEW 2024 and open the file manually. I think Windows remembers which version you used the last time and opens VIs with that version. I am almost certain I read about a wrapper that let's you choose the LabVIEW version to launch but I cannot find it right now.
(1,675 Views)
I appreciate the fast response.  In an effort to be prompt: the short answer is that this halfway worked.  It worked for one VI but not another one.  I apologise but I don't have any insight as to why, I am still trying to troubleshoot it.
(1,651 Views)
