XNET Database Editor - Arbitration ID
Hi, I tried to open DBC file at XNET Database Editor, But it was failed.
When I tried to open it, I can see "Warning: DBC file appwars to be empty. This could mean that the file is corrupted. Close this file and opwn a valid database file."
But I can use this file well at Vector CANDB++ Editor. How can I work this file in XNET Database Editor?
And I tried to create new database file in XNET Database Editor, But I cannot use HEX number it is only accept DEC number system.
The frame's arbtration ID is wriiten by HEX so I wanna use HEX number, How can I solve this issue?
(1,028 Views)
Your question is best posted on the Automotive and Embedded Networks board
Without the problematic DBC, there is no way for us to understand what went wrong. You can create a test DBC without any proprietary information that would reproduce the issue, and post it here.
(1,000 Views)
