Hex data to file jpg
Hello, I have an image as a hexadecimal representation in a text file ( which was extracted from the serial port).
I need to convert this hex respresentation to jpeg files.. How I can do it using Labview?
Here is the file txt:
Message 1 of 27
(7,838 Views)
Hi WSalas,
what have you done so far? Do you have your data as byte array or as text data as in your file?
Attached you will find a part of an example which shows how you can solve it with the data from the given file. The black parts are to make it more interesting for you.
Hope it helps.
Mike
Message 2 of 27
(7,819 Views)
If its in byte array how do we convert to image? Thank you in advance
Message 3 of 27
(6,597 Views)
Hi praveen,
what is in your "byte array"?
Any example data or VI?
(Why did you wake up this old thread instead of creating your own one?)
Message 4 of 27
(6,593 Views)
The byte array consists of equivalent decimal value. attached.PNG file
The VI just read the data from the serial port.
I am using Grove serial camera.
Message 5 of 27
(6,590 Views)
Save the data to a file and give it a filename with a JPG suffix (or whatever fits to your files)…
I guess the algorithm is described in the manual of your camera!?
Message 6 of 27
(6,588 Views)
Dear GerdW,
Is it? Do i need to change to binary or not?
Not really. (The data sheet is attached) I am using sec 4.1 to get the data. (4.1 JPEG Snapshot Picture)
Thank you.
-praveen
Message 7 of 27
(6,582 Views)
Dear GerdW,
Thank you.
-praveen
Message 8 of 27
(6,581 Views)
Do i need to save in hex or binary while saving the data? Anyway i will the both.
Not really. I attached the camera user manual for your reference. I am using section 4.1 to get the data. (data size 512 byte).
I am confused that how do i arrange the 512 byte to get an image.
Message 9 of 27
(6,578 Views)
Hi praveen,
When you request JPEG data you will get JPEG data!
No need to convert to "binary" or something else - just save the data to a file!
Then just follow the descriptions: set the block/packet size and request as many packets as needed. Save their content to a file…
Message 10 of 27
(6,576 Views)
