LV 2021 thick line decoration changed
The thick line changed in LabVIEW 2021.  More specifically, it looks like it is now anti-aliased with smooth edges.
While that is a nice feature, it breaks a bunch of my old UI things where I had expected the thick link to have no aliasing.
Ideally, this would be an optional property of the line decoration.
Thoughts?  This seems bad
See below:
Message 1 of 12
(2,287 Views)
Accepted by topic author brentjustice
Add this to your labview.ini and the good old sharp lines are back:
SmoothLineDrawing=False
Message 2 of 12
(2,152 Views)
I don't see any anti-aliasing, no matter what I set "SmoothLineDrawing" to.
Message 3 of 12
(2,142 Views)
It's for line decorations only (and the objects that include them). Other cosmetics seem to be unaffected.
Message 4 of 12
(2,126 Views)
I never get smoothing.  It always looks the same regardless of the state of SmoothLineDrawing.  It always looks like this:
Message 5 of 12
(2,110 Views)
Maybe it's a difference in what graphics cards or drivers you're using??? 🤔  For some strange reason, I see Paul working on an old Mac.  Probably a Lisa. 😅
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 6 of 12
(2,106 Views)
I am old and crotchety, and do tend to hang on to old stuff as long as it works, but  I'm not that bad.
I've tried it on 2 different Windows 10 machines (one laptop, one rack-mount)
Message 7 of 12
(2,102 Views)
I just discovered this a few days ago:
The change seems to have happened between LV 2021 and LV2021 SP1.
What version are you using?
WOOT!  Thank you for the INI key
Message 8 of 12
(2,090 Views)
If I might ask, how did you figure this out?
Message 9 of 12
(2,088 Views)
I'm right there with you Paul.  My first PC was a Mac 512K with TWO floppy drives!  The Lisa was way too expensive, but I hear it was quite a powerful machine in its time.  Just like us.  😎
BTW, I tried the SmoothLineDrawing=False trick and it didn't work for me either.  I have a basic HP i5 Win10 PC but it does have a GTX1050 GPU so I expected it to work.
EDIT: Just saw the post about it happening in LV2021.  I'm still on 2019.
Message 10 of 12
(2,079 Views)
