Hexadecimal string array
@GuenterMueller wrote:
Admiration to your patience, Gerd.
Danil: How about having a look at Darren's Nugget which handles the common use cases of case structures?
A good nugget to remember 🙂
Message 11 of 14
(1,006 Views)
     what Iam trying to do is in the attached VI.
     Sending data from one VI and receiving it in another VI.My question is:-
       1)Can it be done using serial port reading??Assuming "data sender" as an external device and reading and displaying them in receiver.
       2)As I have no hardware and the only available thing is a null modem cable,to connect between two ports,is it possible using VISA read and write??
       3)Is there any methods otherthan VISA to be used here??
Thanks as kudos only:)
Message 12 of 14
(992 Views)
Hi danil,
all this has already been discussed in your other threads. Is there any new feature? Again your questions are totally unrelated to the topic of this thread...
Please ask again in your older thread to keep topics in one place or follow the suggestions given there!
1) How can you send values from one VI to an other, when your data source is an "external device"? Did I mention you have to write better questions?
2) it's possible
3) VISA is to be used for serial port communication...
continued here...
Message 13 of 14
(990 Views)
"Assuming "data sender" as an external device"
Because no actual device to send data.Just assume that "data send" acts as a device that sends data.
Message 14 of 14
(980 Views)
