Hey guys! How do I keep the flow going using this state machine method? Can someone please help?
I want the flow to keep going continuously unless I abort/stop the run.
When I run the code, I get this flow:
Main Group -> Group 1 -> Main Group -> Group 2 -> Main Group -> Group 3 (My code stops here), but I want this to repeat the cycle back from Main Group -> Group 1 -> Main Group,..., without having to make the array of enum bigger than it is. I would like to keep the same method if that's possible. I have attached my block diagram.
Message 1 of 10
(1,880 Views)
Accepted by topic author GRCK5000
Try this:
No!! Your code never stops because you are autoindexing on a while loop! Once the array runs out of elements, it will repeat the default value forever, especially since you have no way to stop the loop (Aborting the VI is not quite the same ;))
Message 2 of 10
(1,866 Views)
Hey Mr. Christian Altenbach, the LabView champ. I tried that it seems like it's not working. I am not able to move to Group 1. See attached file
Message 3 of 10
(1,831 Views)
Obviously, you need to connect the array index input to the R terminal output, not the IQ. Compare with my picture.
(You also need a wait inside the loop, else you would not even be able to follow it)
Message 4 of 10
(1,825 Views)
If you are going to do something weird like that, I think this would be simpler:
=== Engineer Ambiguously ===
Message 5 of 10
(1,814 Views)
WOWW Mr. Altenbach, you are awesome!!!! You get everything figured out. A challenge is not even challenge to you. What do you not know?
You are the undeniable labview champion.
Message 6 of 10
(1,776 Views)
Thanks RTSLU!!!!  "something weird" 😆 . This code is definitely simple.
Message 7 of 10
(1,760 Views)
It works but think about how you would scale this into a larger more complex program... It wont be easy.
You are basically making a Queued State Machine, a QSM is a tried and true architecture but this is not how it should be done.
Message 8 of 10
(1,757 Views)
Yes, I was thinking about it. You're right, especially when conditions are involved in order to move to the next state.
Message 9 of 10
(1,742 Views)
You are right RTSLU.... And now I wish I would not have suggested it in the first place. 🤐
Former Certified LabVIEW Developer (CLD)
Message 10 of 10
(1,713 Views)
