Hi I want to get my data to text form
I'm using keithley 2450, and I want to get my data as a text form or excel..
but I don't know how,,
and I think there's a power limit because when I put values over 1V, the program says "exceed Power limit"
anyone who might help me?:(
(1,158 Views)
Accepted by dfwfaef
Hi dfw,
So you "don't know" how to get your "data as text"?
You already get the "data as text" from your device! Use File functions to save that text into a file…
I guess the real problem is your lack of knowledge about LabVIEW, so I recommend those "Training resources" offered in the header of the LabVIEW board…
I guess you should read the manual of your K2450 device to learn about all its options/specifications. This should give you the answer about the power limits and how to set/change them…
(In your VI there is only one control labelled "limit". As it is connected to a "Configure Output" function it may help to read the help for that specific function, too.)
(1,136 Views)
