Hi convert my vi code
Hi
     anyboddey convert my example code.vi (5.0 ver) to  8.5 ver.
thanks
KriSH
(3,517 Views)
this is a "good" aspect from Labview : you can't open old files ! Maybe by installing old versions from 5.0 to 8.5, and it is not sure !
Labview isn't perfect, and on ni.com, there are still exemples that can't be opened...Smiley Mad
Good luck !!
V-F
(3,497 Views)
Hai ramses64,
Actually its not like what ur thinking.
see here
Hope u understand
Mathan
(3,494 Views)
Do you mean ALL of the VI's that you have zipped up? 😮
(3,493 Views)
Hi Nathan,
oups, you're wright, It is verry easy, and quite simple !
V-F
(3,489 Views)
When you install LV8.5 (including examples), you should have access to the sound examples.
See below:
Message Edited by JoeLabView on 06-20-2008 08:44 AM
(3,487 Views)
