datasocket
Hi
I want read some shared variable (boolean tipe) with Datasocket, see my VI attached...
If I run the VI with Highlight Execution it works for  the most part of the shared variable that is reading and give just sometime the error at the block "convert variant to data" ,
if I run in normaly mode it give me always the error.
I developed this block how many example explain, what I wrong?
Message 1 of 8
(4,517 Views)
Hi enzo78,
are you sure you receive boolean data? There is an OpenG vi, with which you can check the type.
Hope it helps.
Mike
Message Edited by MikeS81 on 06-20-2008 11:51 AM
Message 2 of 8
(4,512 Views)
Where can I find this OpenG?
Message 3 of 8
(4,509 Views)
Hi enzo78,
here is the link to the package: http://wiki.openg.org/Oglib_lvdata
Mike
Message 4 of 8
(4,499 Views)
As Mike mentioned, you want the lvdata library.  This is the specific VI that you want:
Get TDEnum from Data
Message Edited by Jim Kring on 06-20-2008 04:55 AM
Message 5 of 8
(4,488 Views)
Hi
first of all, thanks for the help.
I haven`t in my library that block, I can`t find it, but I put an indicator on that variant and it give me this output:
FALSE
5 Attribute(s):
   'OdcFlags' -> 7
   'Quality' -> 0
   'Status' -> 0
   'TimeHigh' -> 29938356
   'TimeLow' -> 2686954624
What means? Can it be helpfull?
Message 6 of 8
(4,477 Views)
Hi enzo78,
i think it is a cluster, so that´s why you get the error, you can´t convert cluster to boolean.
Mike
Message 7 of 8
(4,475 Views)
@enzo78 wrote:
Hi
FALSE
5 Attribute(s):
   'OdcFlags' -> 7
   'Quality' -> 0
   'Status' -> 0
You need to install OpenG in order to find this VI:
FAQ: How to Install OpenG libraries onto LabVIEW?
Message 8 of 8
(4,470 Views)
