Hi
Hi all
how to set shortcut key to control in the front panel,
like Ctrl+d, ctrl+s and not with function keys
-Jagan
Message 1 of 13
(7,523 Views)
Right-click the control and go to Advanced>Key Navigation
Christian
Message 2 of 13
(7,514 Views)
In that option only given to set with function keys (F1,F2 ... F12 ) like Ctrl+F1 and not with user defined.
I want to give shoertcut key as Ctrl+R, for that what i have to do?
-Jagan
Message 3 of 13
(7,489 Views)
Hope it will help.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 4 of 13
(7,480 Views)
Hi Balaji,
Sorry, Im  using labVIEW version 7.0.
-Jagan
Message 5 of 13
(7,473 Views)
Accepted by 2716jag
find the vi in 7.0
Message Edited by Baji on 03-31-2009 03:43 PM
Message Edited by Baji on 03-31-2009 03:44 PM
Balaji PK (CLA)
Message 6 of 13
(7,468 Views)
hi Jagan,
i am sending one vi in that i have tried  what u told that is working check the file..................
Santhosh M
Message 7 of 13
(7,452 Views)
Nice solution:
Two minor points:
  1. I would use the Vkey value and ASCII code, this is keyboard layout independent opposed to Scancode. I am not sure if LabVIEW 7.0 has Vkey
  2. I woud use the Code Capture Tool to create images*.
    Ton
    *it is great for this purpose, you select the part you want to capture, start the tool (Tools->Code Capture Tool), review your setting (FP-none, BD-selected, Clipboard-FileName), finish the capture.
    Then you switch over to your internet browser, in the file dialog you past the file name from the clipboard and the file is attached.
    To download
My LabVIEW Ideas
Message 8 of 13
(7,395 Views)
Hi Jagan,
Is your problem solved? If so please mark the post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
Message 9 of 13
(7,343 Views)
Balaji
Yes my problem solved. thanks for this much help.
How to mark amessage as solution ?
-Jagan
Message 10 of 13
(7,310 Views)
