Hidden property nodes
I was going through, one example (shipped with LabVIEW itself), and found following property node.Hidden Properties.png.
Now if I copy it and try to use, I'm very much able to do so. But I'm unable to create the same property node from scratch.
By creating property node I mean to say:
1) On placing a new property node on block diagram
2) Changing the class of node to VI Server >> VI
3) Browse for 'Diagram' property of VI class..... and I'm unable to locate it... Smiley Sad
Please someone tell me the reason.
P.S. I'm using LabVIEW 2009, Professional Development Suite
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 1 of 8
(6,853 Views)
These are scripting functions. They are included in 2010, but in 2009 you need to install support.
See here for details.
Message 2 of 8
(6,845 Views)
You can try this.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 3 of 8
(6,842 Views)
Thank you Mr. Altenbach for the real quick reply.
I forgot to mention,
though I've modified the LabVIEW ini file and activated following items:
a) SuperPrivateScriptingFeatureVisible=True
b) SuperSecretPrivateSpecialStuff=True
still 'm facing the problem.
Is there any key to be added (in the ini file), after that I may be able to use/find those properties.
Message 4 of 8
(6,833 Views)
Accepted by moderator1983
Did you look at the link I posted above?
Message 5 of 8
(6,829 Views)
Hi Mr. Gaurav,
I'm looking for the 'Diagram' reference and not the 'Panel' reference, so this will not help.
Anyways thank you for the reply.
Message 6 of 8
(6,826 Views)
Thank you boss.
Message 7 of 8
(6,823 Views)
Try this in labview.ini
server.viscripting.showScriptingOperationsInEditor=True
Message 8 of 8
(5,055 Views)
