Hide input parameters from HTML report of LV Unit Test Framework
I'm trying to hide input parameters from HTML report of LV UTF.
According to requirement of project, input parameters in html report is not required.
I have attached test project to this post. Run "Run Test.vi" in project.
(3,082 Views)
Accepted by topic author atul_ghumade
You can remove the input parameters from report by opening the *.lvtest file in 'External Viewer' (which is probably MS Excel).
Let me know if that helps
(3,076 Views)
Thanks LVK. Its really worked.
(3,069 Views)
