Hiding a column in array from data imported from excel sheet
Hi
I would like to ask how to do hide columns in an array.
I would like to remove columns with Time1 to Time6.
The attached file is my front panel and block diagram.
Thank you.
(2,408 Views)
Hi ace,
Why do you think we will be able to edit your code using LabVIEW when you only attach some images?
When you want to "hide" columns then you need to delete them from your array before wiring that array to your indicator! Btw. I don't see any columns labelled "Time1 to Time6"…
(2,390 Views)
