Hiding the VI-Bar on the Processline
Hi Labview users and developers.
Is it possible to Hide a Processline Bar for a running VI.
I have developed a program and The main routine starts by a Caller routine that cant be used after the Main routine  Runs. Though I got three Process Bars showing on the Process line, and only the main VI and the Caller Vi are actually running!
There must be a solution for this or how?
Best Regards
HZ
HFZ
(3,777 Views)
For a build app, add to the ini file:
HideRootWindow=TRUE
Felix
(3,760 Views)
Hi Felix, there are two .ini files, the setup.ini and the one with the same name as the Program name, Program.ini
HZ
HFZ
(3,747 Views)
<ProgramName>.ini
Search for HideRootWindow site:ni.com will give you more about this, eg here is a helper vi:
http://decibel.ni.com/content/docs/DOC-1153
Felix
(3,738 Views)
Dear F. Schubert
Thank you for trying to help me.
But non of this could help me...
I have tried this before, about the Hidrootwindow, but nothing happens at all.
And about the VI, that will help hide the Program Task 'Bar'. How is it possible to mannage my program VI's To understand a external VI. When nothing is conected to it.
May be it is me ?
Please help if you got some one got the ability.
Best regards
HFZ
(3,677 Views)
