Object specified is not creatable in my Open reference
I'm having a problem using a type library file.  The file I'm using shows the object I would like to create as creatable (i.e. it has a dot in front of it and shows up when I check the box "show only creatable objects")
Yet when I select the IRemoteInterface2 the reference that is selected in LabVIEW is the first one (IRemoteInterface).
I Then need to go into the reference and select the Interface2 as in the picture above.
When running this I get the error of "Automation Open: Object specified is not creatable in Untitled 1".  I'm wondering if anyone understands what is going on with this error.  The typeLib is registered and a VB project can use this object... here is the VB code:
Dim WithEvents Remote As RemoteInterface
Dim Remote2 As IRemoteInterface2
Private Sub Form_Load()
    ' create the new RemoteInterface
    Set Remote = New RemoteInterface    ' local
    Set Remote2 = Remote
End Sub
    Remote2.ExecuteScript (strFile)
Any ideas as to what I can do to get access to the RemoteInterface2 object
(3,463 Views)
It looks like all these interfaces are implemented using a single coclass (IndiComRemote.RemoteInterface) so try the following:
- Create a RemoteInterface object.
- Use the "Variant To Data" primitive to query for your desired interface, IRemoteInterface2
- If that succeeds, close the IRemoteInterface you obtained first and keep using your IRemoteInterface2 reference.
(3,453 Views)
Accepted by topic author Dave_B
Thanks for the tip about using the variant to data in order to 'convert' or 'access' the other object.  I had tried using the type converter earlier and that caused LabVIEW close immediately.  Here is what the solutioin looks like for accessing the two interfaces.
(3,435 Views)
