Hierarchy Inside LabVIEW
Hi everyone,
I am using LV2019 and trying to call dynamically some VIs from an executable but I have some doubts about the hierarchy that LV creates after building an executable.
First of all, I tried to include the dynamically called VIs in a folder deployed together with the .exe. It worked.
After this, I tried to include these VI's inside "Application.exe", but using this second option I cannot find these VI anymore, using path variables, i.e. "....../Application.exe/Foo.vi".
I was just curious how LV organizes the files inside the Application.exe, or if it really does? I supposed that because LV Executable used to be a pack of VIs, maybe it is all machine compiled, but then this "include function" wouldn't be useful at all.
Assuming I am doing something wrong, and you can access, here there are few questions:
- Is there any hierarchy that I am not getting?
- Does it work the VI "List files and Folders" from LV? (It dit not work for me).
- Including the VIs inside the "Application.exe" would increase the application overhead, or just when the VIs are in fact called.
Thanks for any help in advance, I've been trying hard to find some documentation here in the forums, but I've just got old topics.
Regards.
Felipe Pinheiro Silva
Follow my blog for LV content!
(4,150 Views)
Accepted by felipe.foz
If you tick the "Labview 8.2 file structure" you'll get a flat internal structure with everythin in the same 'folder', else there'll be a folder structure similar to your code.
List folders don't work in an .exe.
There should be no overhead apart from the extra loading time if you compare a big .exe from a small one.
For your internal path issue, drop some "get VI path" and show them somehow, like a message box, an indicator or a log file to get a good understanding of what's going on.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,093 Views)
/Y
DItto all of that!
The only thing I can add is using "static Refs" to the target VIs will automatically include the dynamic VIs into the exe and there is no need to fuss over the path.
Ben
(4,055 Views)
Interesting. I'll have to change my approach that uses list folders. Maybe it can get these file names list during the build.
/Y
I tried that. It worked and I could see the actual location of the files inside the .exe
Thank you both for the help.
(4,001 Views)
