High Resolution Polling Wait protected by password
I have an issue with the High Resolution Polling Wait that may be resolved by doing this:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019c9TCAQ&l=es-CL
In order to do that, I need to go to the block diagram window, but the VI is protected by password. I have no idea what the password could be, and I'm stuck there.
Any ideas?
Message 1 of 10
(3,612 Views)
It's not PW protected on my system.  What LV version are you using?
Message 2 of 10
(3,605 Views)
Hi, Paul,
I run NI LabVIEW 2020 SP1 64 bits.
(Thanks for the laugh, by the way)
Message 3 of 10
(3,592 Views)
Same here. I can confirm that the diagram has a password. (might be an accidental oversight).
Message 4 of 10
(3,586 Views)
It is not password protected on LV 2019 64-bit windows10.
Are you using LV on Mac?
Santhosh
Soliton Technologies
Message 5 of 10
(3,573 Views)
No, Windows 10
Message 6 of 10
(3,570 Views)
Accepted by MatiMarin
Sorry y'all, that was me. We added the VI in LabVIEW 2018, where it had no password. Then, in LabVIEW 2020, it got password-protected by an automated process (run by me) because it calls some internal LabVIEW callbacks on Mac (as described somewhat in the KB entry linked above).
I've attached a non-password-protected copy to this reply, saved in LabVIEW 2020. You should be able to drop this in your vi.lib/Utility folder in LabVIEW 2020 or 2021 (backup the original first, just in case). I have filed Bug 1733037 to LabVIEW R&D to remove the password in a future LabVIEW release.
Message 7 of 10
(3,537 Views)
Hi Darren,
Thank you for your help, it was really kind of you.
Matías
Message 8 of 10
(3,423 Views)
Ni LabVIEW vi password protection becomes a joke. There are programs that open any password protected vi in less than 100ms
Message 9 of 10
(2,107 Views)
https://github.com/tomsoftware/VI-Explorer-VI
Message 10 of 10
(2,086 Views)
