High Voltage Monitoring in Labview.
Hello everyone,
I want to monitor the voltage across a device that is used for transformers testing. It has Voltage around 50KV-100KV. and i want to monitor this much voltage in Labview. Indirectly I want to use Labview as an AC Voltmeter (in KV range).  What is the procedure for it and mainly Which one is the cheapest and for it?
Message 1 of 8
(6,149 Views)
You will not find a data acquisition device capable of sampling those high voltages. Once you get the voltage down to a reasonable level (say 10V or so), then there's a plethora of devices that you can use, depending on the form factor that you need (i.e., plug-in card, PXI card, or USB-based device). As for getting the voltage down to a reasonable level, a transformer comes to mind. If you do not have high voltage experience then I suggest you find someone who does, as you are working with stuff that can kill.
Message 2 of 8
(6,130 Views)
M.Mohsin wrote: What is the procedure for it and mainly Which one is the cheapest and for it?
You are asking the worst possible question.  The cheapest method for high voltage testing is going to cause fatalities.  There are some good high voltage probes out there (they are not cheap) and certainly you can build a 5000:1 voltage divider be careful of the component specs though- at these types of voltages things get really squirrely.  Corona and arc management is just the tip of the iceburg, skin effects and voltage coefficients introduce their own challenges.  OSHA (or other regulating bodies) will have their own rules that you better follow as well. Consult with an expert in the field for your area before commiting to a test methodology.
Good luck and don't die.
Message 3 of 8
(6,111 Views)
Accepted by topic author M.Mohsin
Here is a company that deals with high voltage test equipment:
http://www.haefely.com
http://www.haefely.com/10-products/40-high-voltage-konstruction-kit.php
Swiss quality and swiss prices Smiley Surprised
Building AC voltage divider in that class is material science, mechanical artwork (OK, some say plumber artwork;) ) and a lot of Maxwell 🙂
And not to forget the Flux compensator ...
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 8
(6,087 Views)
You People are right, i am new to Power Engineering ... I have consulted the teachers and they are ready to provide a transformer that can bear that much voltage and can change it to a reasonable voltage to be fed in computer. and also being provided by the NI DAQ-USB. thnx all....
Message 5 of 8
(6,081 Views)
Hi, you can find the power transformer test system via: http://www.himalayal.com.cn/Product.asp?partid=302&smallid=367
Message 6 of 8
(5,896 Views)
Buy/get some high voltage multimeter, they probably have a serial or network port, write a small VI to ask for the values. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 8
(5,886 Views)
/Y
Actually I just got a 50kV test head for a Ri=330M Multimeter, DC!   Nice for old TEK scopes ...
Henrik
LV since v3.1
Message 8 of 8
(5,865 Views)
