Saving Adquisition data into a array or matrix
Hi there,
Im trying to save from 2 Daq assistant with multiple channel to an array or a matrix. the problem is that i cant manage to find the right function to do it. right now i save the 5 channels on a matrix but i cant do an index to fill other rows with data. the daq is getting sample by request.
I gonna send the subvi. give me some exemple plz.
(2,615 Views)
I think you should have a look on the "Array" palette where you have many functions which allows you to manipulate array of data (index array, build array etc)...
You also have examples built on LabVIEW if you click on "Help" >> "Find Examples" and specify "Array" as a keyword - it will show a list of examples which might help you.
Celine
National Instruments France
(2,574 Views)
