Hello again!
Well, it's best to clearly define what you're seeing as "noise". Have you looked at the signal with an oscilloscope to see if it really is random noise, or something else? If it's random noise, you can probably get rid of it with a simple low pass filter. If it's something like an oscillation that occurs sporadically, you may have to approach it differently. In any case, I'd look very carefully at the waveform and see what you're really dealing with before you draw any conclusions.
Hope this helps some.
eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
