High precission data capture synchronization NI9775 and 9234 in CRIO9054
I have a CRIO9054 working with NI Linux Real-Time and with NI9775 and NI9234 modules. I want to synchronize the data capture trigger of both modules as much as possible, having them different sampling rates. I have syncronized the capture of both modules by putting the start task of them in the same frame of a flat sequence.
However, the time differences are about 10-30 milliseconds. Is there any better way of doing this task?
(1,409 Views)
Hi tfernandez,
You are reading waveforms and they contain timing information: you can easily adjust the waveforms in postprocessing to start at (nearly) the same time…
(1,404 Views)
Don't have LabVIEW on this computer, but the link below is a nice tutorial.
https://www.ni.com/en/support/documentation/supplemental/21/signal-based-synchronization-of-analog-i...
Your method shown is noted in the tutorial along with its shortcomings. Scroll near the bottom to look for multirate synchronization.
Note you have a DSA and SAR module; the data from the DSA will have a time lag that depends on the sampling rate. Look at the specs for your 9234. This lag will have to be post processed out; you can just change the t0 of the waveform to account for this lag.
(1,341 Views)
